In some of my libraries, the cursor is not visiable on the work area of the Report Design Tab (I can only see it in the toolbar areas). I've tried the instructions below and it didn't work. Any solutions?
Sometimes my cursor vanishes in Report Design and Print Preview.
To fix this problem, go to File->System Properties. (Close Print Preview first.) On the gIDraw tab, check the box 'Use small drawing cursor'. Click OK.
I'll contact you privately so we can troubleshoot this.
I'm having the same issue, I've also tried the above instructions. Any ideas?
