Bit map symbols appear in very low resolution in pdf output
I recently changed the bitmap file that is used as a logo on our logs. The logo is inserted as a bitmap from the bitmap symbol table in the library.  The logo is higher resolution than required and is sized in the report using the adjust height parameter.
On some reports the logo appears highly pixilated on output to pdf.  On others it appears fine even though it is inserted into the report in exactly the same manner and exactly the same size
It prints to hard copy fine.
It previews on the screen fine.
I have tried both the gINT internal pdf generator and acrobat's printer pdf generator.  Both give similar results.  There is no change regardless of what resolution I select for pdf output in gINT.  The output quality option in the system settings tab of gINT is set to highest quality.
Has anyone else run into this issue?
Parents Reply Children
