ASTM Classification Functions
My company uses a custom gINT library and data template that does not use the default Atterberg data tables. I am trying to modify the ASTM_Class_Multi expression to take in data from our custom tables and output the ASTM classifications.
When we receive Atterberg laboratory data it is usually just moisture content, liquid limit and plastic limit. The ASTM classification function requires input from sieve classification that we do not usually have.
Can I modify the standard code:
<<Let(Symbol = _
<<ASTM_Symbol(_
<<SV READINGS.Reading>><<#>>,_
<<SV READINGS.Percent_Finer>>,_
<<ATTERBERG.Plastic_Limit>>,_
<<ATTERBERG.Liquid_Limit>>,_
<<ATTERBERG.Organic>>_
)>>_
)>>_
to only take in the plastic limit and liquid limit for classification for output (and take the data from the custom table GEOTECHNICAL DATA.PLASTIC LIMIT and GEOTECHNICAL DATA.LIQUID LIMIT)?
Thanks!
