Hi
Could you please help with the following:
When I print a fence report, I would like the alignment to be positioned in the centre of the page instead of starting from the left side of the page.
I understand that I can set this in the Fence Report Properties ->Scales -> Distance Axis Offset: Left. (set to 45 on pic attached) However, I would like this to happen every time.
Any idea? :) Many thanks for your help in advance
Barat
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
Answer Verified By: Baratfulemule
