I am using gINT v8i SS2 version 08.30.04.220.
I have input some values for blow count, depth and length. The values I used are as follows:
depth (1, 3.5); length (1.5, 0.8); blows 1st (5, 15, 21); blows 2nd (10, 90).
The chart in the blows per foot I would expect to show the total blows for the 2nd, not just the first row, and the total penetration to read as 100/0.30, and penetration value after 90 blows to read as 90/0.30 (see attached image). I thought the program is supposed to calculate these values of penetrations based on length and assumed 6 inches of length for each successive count until the remaining value, in this case, 0.30 is displayed. However, it does display the information if I type it into the appropriate fields. But if I want gINT to calculate the values, is there a way to force this calculation without programming a script?
Answer Verified By: CADTech1
