I am using gINT v8i SS2 version 08.30.04.220.
When I input values into the Drill Rate Table in Depth column, is depth from ground surface or depth of individual samples? Also values for the Length column, are those lengths considered from ground surface or individual sample lengths? The Drill Time is in a format mm:ss, I assume that is minutes and seconds?
Answer Verified By: CADTech1
