How can I add a new row in report design?
Hi! I was looking the preview for my borehole (using gINT borehole report default), It was Ok but I couldn't see the pictures that I added  in INPUT--> MAIN GROUP--> photo registration.
Then trying to change that I went to REPORT DESIGN--> logs and found the borehole log, I tried to put a new row called "Registro fotográfico", but I don't know how I could link the photo registration in the borehole log.
Sorry my poor english, and thanks!
  • Hello Carmen,
    In order to add photos to the report log, you will have to create a new Bitmap Symbols vs Depth Properties column in the template. On the tool bar select Log>Column Bitmap Symbols vs Depth Properties. In the current template that you have selected, you will have to either move, delete and or reconfigure some columns here to make space for this new Bitmap Symbols column.
    You may want to refer to these articles on the community page that refers to Photo log.
    communities.bentley.com/.../general-purpose-log-reports
    (this link has a zip file called log_a_rnnn01.zip that contains a library and a project file. This would be a good reference point for you to see how the column called Optical Photo is linked to the Optical tab in input).
    You may also want to check this for article for making certain adjustments to the column properties.
    communities.bentley.com/.../165044
  • Hello again!
    I tried to change one column (environmental data) --> "registro fotos", but only changed the name I can't see any photo
    Then I intended with log--> Column Bitmap Symbols vs Depth properties
    I'm looking the yellow requirement and can't understand what kind of information I need to put in "column width expression" and
    "Depth expressions/bitmap symbols"?
    first What's a bitmap symbol???, Is something like a photo link?? 'cause I had uploaded the photos on input--> main group --> photo log
    My knowledge about programming is very bad I can't find a route to link photo with report design!!!
  • Hello Carmen,
    Will contact you privately on this via email.  If you can send me an email (click on my name Aparna M) I will reply to your email as soon as possible.
    Answer Verified By: Carmen Lizana
  • Is amazing I changed it (like the example) and all the photos were appearing, I'm so happy and grateful!!
    Maybe I talk to you soon because I'm learning how to use gINT for my superior collegues (I'm just an student in practice)
    They bought gINT software a weeks ago and I'm just typing data and trying to learn more
    Excuse my english I hope can improve it
    Bye
Reply Children
