Has anyone written a Fence Expression or Report Variable for Direction of Projected Borehole from Baseline?
For example if a well is 250 ft NW of a drawn Fence baseline, I want it to return the solution: “Projected: 250 ft SE to the baseline”.
If no one else has done this, then I'll go ahead and give it a shot.
I think I need to use <<FenceOffsetEast>> and <<FenceOffsetNorth>> in conjunction with some trigonometry functions.
Not sure if this would be best to do in the entity expression, or a report variable.
Thanks,Matt
This solution just works with whatever baseline is used when the fence generates, that could be an auto best fit line, manually draw/defined in fence output, or from the alignment table. Your questions is not applicable. The "a" would be calculated by code you write utilizing trig functions
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
