gINT and Windows 10 upgrade
Hi all,
For those of you considering doing the free Upgrade to Windows 10... I upgraded my system a couple of days ago, Windows 7 Pro 64bit with gINT, CorelDraw X7, Draftsight and a load of other software already installed. The upgrade to Windows 10 pro 64bit went fine, no hitches or problems, andf gINT seems to be working fine. If any of you remember my previous couple of posts re the preview version of Windows 10 and gINT (problems with .NET3 etc not being included in Windows 10 etc) this doesn't seem to be a problem if you're upgrading (as .net 3 etc would already be installed I presume)
So if any of you were hesitating in upgrading because of gINT.... Mind you, I can only comment on my system, so back up your system drive before upgrading just in case :-)
Miles
