I've screenshotted a few things to make it easier to understand what I am on about.
Basically in this screen http://i.imgur.com/fw7uPZR.png
you can see in the type No column it says B3 this is propagated from this table http://i.imgur.com/cZzTdJx.png . what I am trying to do is get the 3 a smaller character case as on some logs it spills over into another column.
The way the language program is set out for the report is this= http://i.imgur.com/ihmkmAH.png the part which I am trying to change is "Samp_ref" found as an additional column here = http://i.imgur.com/MemmG12.png
Thanks for the help I am using AGS4 and Gint logs V8I
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
