Borehole Descriptions With Depth
I  have three layers in a borehole, which show some variation in description with depth. Is there any way of inputting the descriptions in a row so that they appear at the exact depths on the output? This is apart from trail and error and playing with Enter Key and also without creating another row.
  • Not that I'm aware of. As far as I know, apart from the adding a carriage return thing, the only way to control a depth text entities depth is to use a field (ie. a "depth" field), giving it a numerical value, therefore having to add another row for each specific depth. I'd have thought that the only way to do it would be to add another row for each variation, and select the Layer Line Type to none, giving the appearance of one continuous entity with text placed at certain depths, the last entry for that layer then has the Solid Layer Line Type used to differentiate between that and the next layer. Miles
Reply
