I need to output the hole depth on a boring log by finding the deepest value from several tables/fields. This is the expression I used, but it isn't working. I've checked all the table/field names and report variables, and it seems like it should work ... Does anyone have a suggestion?
BOTTOM OF EXPLORATION _<<Format(<<MaxVal(<<POINT.HoleDepth>>,<<Report Var.SAMPLE Bottom>>,<<Report Var.DYE TEST RESULTS Bottom>>,<<CORE DATA.Bottom>>,<<STRATIGRAPHY.Bottom>>)>>, 0.0_)>> FT
The Report Variables are:
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
