I have set up a split log for our rock coring using the "Bottom Depth Expression" feature in the log properties. The bottom portion that shows the rock works fine but in the upper soils part all of the Plot Vs Depth features continue their lines to the total depth of the borehole instead of stopping at the bottom as specified by the "Bottom Depth Expression".
Do these features not use the "Bottom Depth Expression"? Is it possible to make a Plot Vs Depth conform top this?
All other entities stop at the specified depth.
Dave found a bug where plot columns ignore the Bottom Depth Expression in the log report properties. Thank you Dave. It affects depth scale columns too, where the ticks and numbers continue to the bottom of the page. We'll report this to Development.
Answer Verified By: expDave
Did this bug get fixed?
I think I'm still experiencing it in gINT CONNECT Version 10.00.00.48
See https://communities.bentley.com/products/geotechnical1/f/geotechnical-forum/111829/split-rock-core-log-plot-vs-depth-continue-to-depth
gINT v10.0 is years old, use 10.3
I don't think this functionality necessarily a bug, you can have output condition to stop data plotting
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
