Team,
My company is starting to research the use of SQL to host it's gINT data. It is working out very well in our test group. We are able to use the data in a BI software and create boring plans in GIS very efficiently. We are only seeing a few items that we need to do some workarounds or help with. I believe that they are all behind the scene programming.
One is the use of the gINT rule that prompts for the user to update the hole depth in the Point table from Lithology. When the rule is added to the database it will not allow the user to progress past the current table. When this was removed they could continue to work but the user had to review the total depth. User would like this fixed.
The next is in the Graphic Text Docs if a Variable Legend Properties element is used when the output is run ALL the sampler type graphics in the DB are shown. Is there a way to get it to pull from the unique project. I spoke with Kurt in support and he mentioned that Programming would need to review and work on this. I was not sure if there was anyone out there that may know a workaround. I believe this is a Key Set element. I currently have it set on Project in the page properties.
If anyone can assist it would be great.
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
