How can i change the units to SI in gINT? Thank you.
I am a new user. It would be helpful if i can get some advise on how to change the units from feet to metre.
  • Hello Sayed,
    Looks like you are using gINT Std US Lab files. US Std files are all set in English (feet) units. For metric units you may use Canadian files - gINT Std Canada files.
  • This blog shows how to rerun the installer and select more standard user files
    www.datgel.com/.../11-how-to-install-gint-standard-user-files.aspx
    most files are in metric, apart for gINT Std US and gINT Std US Lab.
    Phil Wade
    Datgel
    Bentley Channel Partner and Developer Partner
    E: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
    Get the most out of gINT with Datgel Tools.
  • Hello,
    I have the same question and I used the Canadian files. It does use SI units when you log all your data, but when you need to generate the report, all the leyends say "feet, inches, etc.".
    It would be very helpful if you could help me with this. Thank you!
    Answer Verified By: Aparna M
  • Hello Silvia,
    Under the Input tab, the standard Canadian files have the Units set to Meters, Inches.  When outputing the reports using standard Canadian library, all the legends do show same units - metric, inches.
    Have you changed their labeling in the Report Design?
    The standard report using Canadian project and Library looks like this
  • Hello Aparna,
    I did not change it because I couldn't do it. This is how my reports look like, using the Canadian files.
