Editing blocks in gINT Report Design > Logs
I am new to gINT and trying to modify/edit the output display of borehole logs generated by gINT to better suit our company needs. My question relates to Report Deisgn > Logs menu of gINT software. I am trying to modify a log report captioned as "Geotech BH Columns". In this, a dashed line displays the border of my output page. Outside this dashed outline of page border block names in different colors are written. For example, I have two blocks named as "INT LOGO AND TITLE ALL" and "INT PAGE 1 HEADER PAGE 1" displayed. Now I understand that I can modify the basic properties of the block by double clicking on the block name and playing around with the properties. However, if I try to modify the contents of each block, I am unable to do so, i.e. I can not select any of the items of these blocks for editing.
For instance, "INT PAGE 1 HEADER PAGE 1" block shows three water table values, i.e. WT at the time of boring, WT at the end, and WT after 24 hrs. I want to delete two of those and show only WT after 24 hrs. How do I delete it?
Any help in this regard would be highly appreciated. If someone can share any tutorial video or help file related to modifying the report design, it would be a great help.
Irfan
Parents Reply
  • Hi Richard,
    A private block is on the report itself therefore the entities are edited direct in the report
    A private block is a part of the report it’s inside of. This is unlike a drawing library or internal block, which is a library object that exists outside the report, and is included into it by reference. Private blocks are no more than a grouping mechanism for entities in the report. However, they are very useful for displaying or suppressing a group of entities together, as well as for moving a group of entities a specified distance in response to a specified condition.
    Please see working with private blocks
