gINT "Boundary Line Breal Indent" error
Hey guys, how are you all doing?
So here is the deal: I am trying to translate a log template. The problem is when I open the properties for some of the entities on the Report Design tab (Material Description, Well Diagram, Environmental Data, etc), an error occur regarding a field named “Boundary Line Break Indent”. The program asks for a value smaller than the third of the “Column Width Expression” but it does not accept any value that I try to input and I can’t change any of the properties. The thing is that the program stop asking for this value  only when I clear the "Boundary Line Depth Expression" and "Top Boundary Line Depth Expression" fields and I choose to not display any line at hole depth.
Do you know what might be happening?
  • Hi Lucas,
    I am not seeing this behavior if all three items you suggest are removed. If just one of them has data, then you will see the message you get.
    I do see a boundary line fix in a very old version although the behavior is not exactly the same.
    I am using the latest version of the product. I would check to see how old of a version you have . Open gINT go to Help ...about gINT if you version is less than 8.30.04.285 for the V8i series or the connect edition version 10 you may want to try the latest version.
Reply
  • Hi Lucas,
