Lab Soil Index >LL PL > Passing 425um
Using gINT V8i : Professional. Data Template: gint std ags 4_0
There are several cells within the lab testing section that will import results from the Particle Size room (GRAT) and I am wondering if there is a way to stop this.
My specific problem is the Passing 425um cell in the PI room; there may be instances in which we would use specific portion of material for the LL/PL test and would want the results being reported in the 425 cell to match this portion and not the entire sample tested in the Particle Size room?
The remark for this cell is "Will be calculated if there is an associated GRAT (Particle Size Readings) dataset".
Any help appreciated.
Graeme
