How to input multiple well installation details
Good Afternoon
I’m in a similar situation now as the person who originally posted the question (10 months ago) was back then, creating a newer version in gINT and getting used to some new features. But what do you do for multiple installations in the same hole?
When I add them with different pipe references but start them both at ground level (0.00) I get an error message pop up (see below).
When it’s changed to be the same as the previous ‘Base’ value the 2nd installation starts at that new depth (see installation details on the right).
Lastly is there a way of showing on the output if a piezometer was used instead of a slotted pipe?
Parents Reply Children
