We'd like to output all of the SI for a project in order of chainage. Phil Wade has helped by explaining how to output logs in order using the sort box on output.
How can we extend that functionality so that the output for TPs, BHs, RCs, CPTs, DPs are output using the appropriate report log.
Ex:
TP101 (chainage 0+100) is output on a TP report
BH101 (chainage 0+200) is output as a BH report
TP102 (chainage 0+300) is output as a TP report
First, you need to have code in Report properties | Report Structure | PointID Output Condition to only let the relevant Hole Type print for each report.
Then, use the Datgel Output Tool ().
Set options:
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
