I am very much interested in making a template to have a subsurface profile in gINT. I have a template that gives me a similar profile using output>fences, but that template only gives me the blow counts and not the complete lab test results, such as the one depicted below. Can anyone please help me figure it out how to implement the test results in the output?
Many thanks in advance.
Sepehr
The question you are asking is somewhat file specific. Generally speaking to display text values (like lab results) on a fence would be to use a text vs depth entity for each lab test you want to display or a single entity with multiple lab tests. Since a gINT database is user defineable (customizable) It would be difficult to give you exact instructions without seeing your files (IE library and Project). The Fence tutorial shows how to create a text vs depth entity you would just need to write the expressions to call data in from your database where the data resides (IE what table , what field) Below is fence tutorial. If you want to send me your specific files I would be able to look at them and give you some advice. kirk.johnson@Bentley.com
