Hello - we are working with a DOT which uses Microstation and needs us to create our logs using their material graphics. Is there a way to import their graphics into our gINT library? (thanks in advance...)
Hello Tabha,
gINT can import graphics symbols from one gINT library to another, but not from MicroStation to gINT.
Based on the current material graphics in your libary, you can create new symbols within gINT which are close to the symbols that you want import from MicroStation.
In case you want to know more on how to create new symbols, here are a few links that might help you:
