I recently downloaded gINT Civil Tools and for the time being, am just trying to get acquainted with the program for evaluation. I think my main use for the program would be to load a database and query drill holes based on certain properties. If I connect to a database and try to do an advanced query, I only see the option to query PointID, East, North, Elevation and Depth. Is there a way to query based on other properties in the Point table? For example, my database table is coded to differentiate between holes of varying drill methods and I would like to see just the core holes on a site.
Any help would be appreciated!
Sam
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
I want to complete an advance query based on a Borehole Point ID which has a Prefix. For example I have 3 types of boreholes. ML, BD and SD. Is there anyway to filter by this property?
I've tried wildcards BD* but it will only filter if I put in the exact point ID.
Any suggestions?
Its ok. I have figured out that we can use a Location Field in gINT to filter the data. Thanks
