Referencing gint alignments
Hi. I am trying to create a legend for a fence diagram. To do this, I created a polyline with type=By layer, thickness= (blank), and color=By layer. Under the Configuration tab, I've set the override line type, thickness, and color expressions to the corresponding GINT_ALIGNMENTS.Z1 type, thickness, and color. However, when I output, the polyline is displayed with the default properties and not the override properties. Any help would be appreciated. Thank you.
  • Hi Allan,
    The only legend entities for a fence are graphic legend and surface legend. To make what you want we would really need a new feature ..alignment legend.
    The only way you can show it now would be to hardcode the color and line type. But it would not dynamically change with each output (ie referencing data from a field)
    I will add it to the list of enhancements for our development team to review.
Reply
  • Hi Allan,
