Dear gINT community,
For the last weeks I have been banging my head against the wall to figure out how I can resolve the following error. In my lithology tab I would like to hide some fields, hence I go to Tables > Show or Hide Fields and the following message pops up:
Invalid procedure call or argument
MainCmd.CmdControl
MainCmd.CmdExecute CmdID: 610 'Show or Hide Fields'
appInput.CmdControl: gINT8a
In the point tab and project tab I have no problem with the "Show or Hide Fields" command. Does anyone know how I can resolve this error?
Thank you,
Thomas
HI Thomas, If you have a very old version that could be the issue. 1. Try to make the change in DATA DESIGN. Open the project goto DATA DESIGN. Hit the open file button choose current project. The yellow box at the very top is the table name . Pick your table. Then in the middle of the screen is the list of fields, pick the field. choose the hide property. Save and go back to Input. 2. check your version number and update. 3. If neither work send me your library and project and I can take a look.
Thank you David. This works perfectly.
Kind regards,
Thomas Hull
