I am trying to open gINT but I can't get it to. I keep getting Run-time error.
Hi Immanuel,
A runtime error by itself is fairly generic in nature and we would probably need to look at the individual machine to determine the issue. But if you have multiple errors that follow including an error about running "scripting" on this page then it is most likely an error that can occur on older versions (about 2years or older) of the software which used to have a built in web Browser. If you are getting a scripting error then there are a couple of options. If you are eligible to receive the latest versions of the program then you could install that because the web browser was removed almost 2 years ago. If you are not eligible or choose to stay on the old version then the web browser must be disabled. Please see details in below link to hide the browser.
run time error
