Is there a download to allow the user to enter lab data from Triax and Consolidation tests into gINT?
We need a library addition to allow us to enter lab data for Triaxial and Consolidation tests into gINT and it will calculate and output results.
  • Hi Peter,
    This answer applies assuming you want standard US lab testing and that you have a license of gINT professional.
    The gINT standard US lab file set includes tables with data entry and calculations as well as a graph report in the library. It can be downloaded here.
    Available gINT Standard Reports Each set of files contains a library with report templates, a sample project and a data template. The report templates in these libraries have been designed to support…
    There is also a free triaxial graph report available. It also requires gINT professional. It can be downloaded here.
    GRAPHS Graph reports are a common way to display plots of dependent data vs. some independent datum. A gINT graph report allows you to combine drawing elements with the graph of values against a variety…
    If you are not using the gINT Standard us lab file set and are trying to intergrate  it into your custom gINT files (especially where you already enter lab data) IE in a sample table, then you may want to contact us privately so we can look at your custom gINT files.
