Does Bentley gINT sell a data template and library for USACE 1836 boring logs?
Hi Greg,
We have a couple on the free reports section under agency reports. These are free to use and edit as you see fit. Remember many divisions have their own variation or updates of this form. I would suggest contacting the division you are working with directly to see if they have gINT files for download. Here is link to our free reports agency page.
Great! Thanks for the info Kirk. And the link. This was very helpful.
You should be able to download these for free here: https://communities.bentley.com/products/geotechnical1/w/wiki/3858/agency-reports
You would probably want to edit the library report to map to your database structure if you already use a different database template than the standard
When I try to open this I get an error that says I can't open the library because it was created with a previous version. Has anyone else experienced this issue?
Hi John,
The cause of that message is described in the "Older Projects" section at the bottom of this post.
I posted updated files that will be compatible with gINT 10.01+.
There may be other Agency Report files with the same issue. Here's a post describing the solution. You simply need to open the files in a version of gINT v8i or gINT 10.00, and they will automatically be updated so you can open them in gINT 10.01+.
