hi,When I open enterprise db,
and select a gint db(non gINT SQL db, just an empty SQL2012 db,gINT is 10.00.00.50 plus),
then it prompted a error.So why I have is error?how to resolve it?
Hi Sun Ze
If you made that database in SSMS, then that is the problem. You need to make databases by up sizing from the gINT application.
I guess you are somewhere in Greater China. I'm in Hong Kong this week, if you need some professional help with this.
regards
Phil Wade
Datgel
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
Answer Verified By: sun ze
[AUTOMATED MESSAGE; if there is a link below, please follow that if you wish to respond to this Communities message.]
RE: open enterprise db
Did this answer your question?
Verify it as the answer or Reject it as the answer
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
1. use AD user accounts
3. it doesn't, use AD user accounts
