Hello, I have two small questions that I cannot find the answers to... I am trying to clean up a borehole log and have two details I would like to change in the report template.
1. I am looking for some instructions on how to change the the scale on the left?
2. What is the feature name of the horizontal line between lithologies? As you can see it overlaps the well design and I would like that to not happen.
I've included a small screenshot below.
Hi Ismena,
Both of these questions can be file specific. Unfortunately I am not seeing the screenshot.
For question 1 . If you mean changing the number of feet or meters per page that is usually set in the Depth log page field of your INPUT. Either in the project or Point (borehole table) , But it depends on how your files are set up. If you are talking about changing the increments shown (ie scale numbers every 1 foot or 5 foot or 10 foot) That is a property of the scale entity on the report.. Goto report design..double click on the scale column to open its properties and go to scale numbers to edit the increment you want the numbers to show.
For question 2 The boundary line property on your material description column in report design sets the lines but if it is crossing into other columns then you column width expression is probably not right. In that case I would need to see the files. You can send them to me. Library and project. kirk.johnson@Bentley.com
