I have several shallow boring logs that only reach 7ft bgs. right now, when I export the boring logs, the information is all smushed up at the top. How do I space the info out and make the page show only, say, 10 ft at a time rather then the 30 or 40 it defaults to?
If you are using one of the standard file sets then you can override it in INPUT at the Project level in the Project table Depth Log Page Field or at the Point level in the bore hole table (point) Depth Log Page field. Put in 10 .. That will be the number of feet show on the first page.
Change the number at the following location;
Report Design > Log Report Properties > Report Structure > Depth Units Page 1
