I have setup a brand new project using the 'gINT Std AGS 4_0' Data Template, using the 'gINT Std AGS 4_0' library. This is using Connect Edition as gINT Professional v10.00.00.50.
When I import a standard AGS 4.0 file that has been issued to us via a client (stringently checked both structurally and content-wise by them when received from their contractor) it is stalling during the import of the ERES table and gINT gets to the point of 'Not Responding'
All files are on my local machine. All files to be imported are on the local machine. This has been tried on multiple AGS 4.0 files provided by the client which resulted in the same outcome - the only difference being the percentage at which the process stopped (93% on one file and 63% on the other). To get an idea of numbers one of the files had around 7,700 results in the ERES table (only 4,600) were imported.
Are there any known issues / fixes?
Paul
The file is imported using the 'gINT std AGS 4 from AGS 4' import file.
I have no easy fix but when encountering similar problems I have found that splitting the ags file into smaller easier managed tables and then identifying the rogue table
Roger
Thanks Roger.However, with other software I have had no need to split any AGS file to ensure all of the contents import. The whole point of an AGS transfer is lots of data in one file.RegardsPaul
I know. I have even had the same problem when importing a file I have previously exported. It's beyond me!
I'm reasonably new to gINT and to be honest, these aren't the types of issues I was hoping to run into at the outset.How long have you been working with it?
