Hello - I have a project where the borehole locations span over two UTM zones. Is there a way to specify a hole specific UTM zone, rather than a project zone?
Hayden
No, all PointIDs in one project need to use the one coordinate system. You could use gINT Pro Plus with an SQL Server database and have 2 projects, one for each coordinate system. You can output PointIDs from two projects at the same time.
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
Answer Verified By: Hayden Streater
Thanks Phil - This is the direction we are heading down.
