I am trying to find a function that will automate my fence diagram by inserting the alignment offset in my Fence diagram title block. I am not referring to the offset for each individual hole, but for the max offset distance you type in the output tab. All functions I've seen refer to each individual hole and not what I'm looking for.
Hi Justin,
I'm not aware of a Function or Data Item that will automatically insert the Maximum Baseline Offset into your Fence report.
Instead, you can create a User Report Variable where you input the Offset value. I realize that's not ideal because you have to type the number in twice, but it gets the job done.
Setting up User Report Variables for user input is described in the Fence Report Design tutorial starting on page 33 in the "Adding Two Report Headings" section.
Jesse
Answer Verified By: Justin Kline
