Does anyone know if it is possible for gINT to generate logs using data from another SQL Database via some kind of direct link. Or to generate logs, does it have to be referencing data held in a .gpj or a Professional Plus SQL Database?
Discovered the SQL wrapper.
This works: <<Sql(Select count([VW_POINT].[PointID]) FROM [VW_POINT])>>
