I have a gINT Civil Tools 3D model, to which I have connected a gINT project database. I mapped to the Borehole, Lithology, AND Water Levels tables and queried data. When I try to connect to a second database which contains additional borings, I am unable to complete the connection. The Database Connectivity and Mapping window prompts me to define the "mandatory field depth in the table Water Levels". When I try to define the field in the table mapping tab, although the second database contains a Water Levels table, I cannot see the Water Levels table in the pull down list, and therefore I cannot define the field. I suspect this may be due to the second project database containing no data in the Water Levels table. Is there a requirement in gINT Civil Tools for data to exist in all tables mapped?
OK. So I set up this mapping. Notice the mapping to Lithology and Descriptions. When I'm done, I save the .xml file and plan to use this as a seed for all of my other projects.
Then I switch and open another file. I load a copy of the .xml file I created above. The mapping I set up is gone. Doesn't matter what gINT project I load, its still missing. Even if I load the original project that was used to create the .xml file. What am I doing wrong? I know the fields I used to do the mapping have data.
