hi,
All of a sudden, my grphical input is not working anymore.
the report is properly built but when i select any field, tables don't show up.
I'm working on Gint 10.00.00.50
Is it coming from the software? it was working so far and is still working on my collegue computer.
Cheers
Marg
Hi Margaux,
It is hard to say without more details, but I would check display settings.
I recommend making sure you are using gINT on your main monitor. If you have moved the program back and forth between monitors it may be possible the windows for GDI mode are hidden. Check which monitor you have set as your main one. Put gINT on that monitor. Close gINT ..reopen then try GDI mode.
If it doesn't work then I may need you to share your screen with me to troubleshoot.
As a backup you can always enter data the traditional way in Grid Data entry, where the information is just entered in the table grid. kirk.johnson@Bentley.com
I had the same issue and this solution did the trick on version 10.02.00.04. I have closed gINT after moving it on my main display and then reopened it and the gdi started showing up. I did not manage to reproduce the error after several trials regardless of the display I was closing it and reopening it from.
