I have imported an AGS 3.1 data file into gINT using the 3.1 to 4 correspondence file. Everything works fine including contaminant data with the sole exception of pH results.
Is there any explanation for this?
Roger
Hi Roger - Could this be to do with them being results for BRE tests? I've just had a look at the "gINT Std AGS 4.0 from AGS 3.1" correspondence file and it only seems to map results from the CHLK table (specifically chalk content). Results from BRE tests were usually stored in the CNMT table prior to AGS 4.0.
Are the pH results just not appearing or are they going into a different table?
