We're working with a very long track alignment (with InRoads) and we would like import this alignment into gINT such that we can use it as a baseline to export the subsurface profile (fence diagrams). We've tried various XML and LandXML outputs from InRoads but gINT gives an error when we tried to import them. Has anyone tried this? Is there a very specific LandXML format that gINT needs for this import to work? Does anyone have an example of an LandXML file that gINT can import as an alignment to be used as a baseline for fence diagrams? We have about 250 miles of alignment so it would be really great if we can fully integrate various Bentley products!
Hi Lucy
LandXML import does work, I tested it extensively when Datgel paid gINT software to create it. This is the process:
<?xml version="1.0"?> <LandXML xmlns="http://www.landxml.org/schema/LandXML-1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.landxml.org/schema/LandXML-1.0 http://www.landxml.org/schema/LandXML-1.0/LandXML-1.0.xsd" version="1.0" readOnly="false" date="2006-06-22" time="08:51:56" language="English"> <Application name="MX" version="" manufacturer="Bentley Systems, Inc."> <Author createdBy="datgel"/> </Application> <Project name="Datgel" desc="Datgel"> <Feature code="MX"> <Property label="X_OSHIFT" value="0"/> <Property label="Y_OSHIFT" value="0"/> </Feature> </Project> <Units> <Metric areaUnit="squareMeter" linearUnit="meter" volumeUnit="cubicMeter" temperatureUnit="celsius" pressureUnit="mmHG" angularUnit="radians" directionUnit="radians"/> </Units> <Alignments name="DESIGN" desc="Datgel"> <Alignment name="Datgel alignment test" desc="Datgel alignment test" length="973.840842414378" staStart="0.0"> <CoordGeom> <Line length="98.9018804871495"> <Start>6072482.543291 261014.194005</Start> <End>6072541.67542543 261093.471824352</End> </Line> <Curve rot="ccw" chord="254.280674032757" crvType="arc" length="255.699927938586" radius="700.0"> <Start>6072541.67542543 261093.471824352</Start> <Center>6073102.78177926 260674.951024751</Center> <End>6072728.19858495 261266.29477465</End> </Curve> <Line length="232.612475842259"> <Start>6072728.19858495 261266.29477465</Start> <End>6072924.70420458 261390.770094987</End> </Line> <Spiral length="60.0" radiusEnd="300.0" radiusStart="INF" rot="cw" spiType="clothoid" chord="59.9733375672768"> <Start>6072924.70420458 261390.770094987</Start> <PI>6072958.51299271 261412.186071493</PI> <End>6072974.27067506 261424.533480822</End> </Spiral> <Curve rot="cw" chord="98.6829427996753" crvType="arc" length="99.133357873255" radius="300.0"> <Start>6072974.27067506 261424.533480822</Start> <Center>6072789.2359441 261660.67358402</Center> <End>6073040.87881698 261497.346107676</End> </Curve> <Spiral length="60.0" radiusEnd="INF" radiusStart="300.0" rot="cw" spiType="clothoid" chord="59.9733375674481"> <Start>6073040.87881698 261497.346107676</Start> <PI>6073051.77769631 261514.138293341</PI> <End>6073070.10585429 261549.715769781</End> </Spiral> <Line length="51.6235125223373"> <Start>6073070.10585429 261549.715769781</Start> <End>6073093.74755623 261595.607566155</End> </Line> <Curve rot="ccw" chord="103.965513658825" crvType="arc" length="104.26040236445" radius="400.0"> <Start>6073093.74755623 261595.607566155</Start> <Center>6073449.33588513 261412.422030838</Center> <End>6073152.9671474 261681.05853486</End> </Curve> <Line length="11.6092853863412"> <Start>6073152.9671474 261681.05853486</Start> <End>6073160.763842 261689.660108</End> </Line> </CoordGeom> <Profile> <ProfAlign name="GC00DESIGN"> <PVI>0.0 9.871</PVI> <ParaCurve length="100.0">138.299429 11.426608</ParaCurve> <ParaCurve length="50.0">357.682018 3.565186</ParaCurve> <ParaCurve length="50.0">635.30853 4.61072599999997</ParaCurve> <ParaCurve length="100.0">908.592235 23.042644</ParaCurve> <PVI>973.840842414378 20.4539999835601</PVI> </ProfAlign> </Profile> <Feature code="MX"> <Property label="subreference" value="MC00"/> </Feature> </Alignment> <Feature code="MX"> <Property label="featureset" value="publicstyles\mfw simple design.fns"/> <Property label="styleset" value="publicstyles\mfw simple design.pss"/> </Feature> </Alignments> <Surfaces name="DESIGN" desc="mfw simple design"> <Surface name="DESIGN" desc="mfw simple design"> <SourceData> <Breaklines> <Breakline name="MC00" brkType="standard" desc="Road Centrelines"> <PntList3D>6072482.543291 261014.194005 9.871 6072485.53272528 261018.201907527 9.92724057927238 6072488.52215957 261022.209810055 9.98348115854477 6072491.51159385 261026.217712582 10.0397217378172 6072494.50102813 261030.225615109 10.0959623170895 6072497.49046241 261034.233517637 10.1522028963619 6072500.4798967 261038.241420164 10.2084434756343 6072503.46933098 261042.249322691 10.2646840549067 6072506.45876526 261046.257225218 10.3209246341791 6072509.44819955 261050.265127746 10.3771652134515 6072512.43763383 261054.273030273 10.4334057927238 6072515.42706811 261058.2809328 10.4896463719962 6072518.41650239 261062.288835328 10.5458869512686 6072521.40593668 261066.296737855 10.602127530541 6072524.39537096 261070.304640382 10.6583681098134 6072527.38480524 261074.31254291 10.7146086890858 6072530.37423953 261078.320445437 10.7708492683582 6072533.36367381 261082.328347964 10.8270898476305 6072535.33635904 261084.97310593 10.8642022072771 6072536.35310809 261086.336250492 10.8826496288557 6072539.34254237 261090.344153019 10.9290015561256 6072541.67542543 261093.471824352 10.95699667132 6072542.33266682 261094.351540206 10.9635828788724 6072545.34265642 261098.344015163 10.986393597096 6072548.38108667 261102.31488853 10.9974337107965 6072549.72065034 261104.047036948 10.9985624583013 6072551.44780256 261106.263957711 10.9967032199738 6072554.54264761 261110.191021223 10.984202124628 6072557.66546392 261114.095878707 10.9599304247591 6072560.81609218 261117.978330937 10.923888120367 6072563.99437162 261121.838179829 10.8760752114518 6072567.2001401 261125.675228453 10.8164916980134 6072570.43323406 261129.489281042 10.7451375800519 6072573.69348855 261133.280143002 10.6620128575673 6072576.98073722 261137.047620923 10.5671175305595 6072580.29481236 261140.791522587 10.4604515990286 6072583.63554489 261144.51165698 10.3420150629745 6072587.00276435 261148.2078343 10.2118079223973 6072590.39629896 261151.879865966 10.069830177297 6072593.81597558 261155.527564632 9.9160818276735 6072597.26161972 261159.150744191 9.75056287352687 6072599.54948763 261161.528110801 9.63489288787751 6072600.73305561 261162.749219788 9.57395411290433 6072604.23010611 261166.322807828 9.39478260171389 6072607.75259282 261169.871325985 9.21561109052346 6072611.30033601 261173.394593214 9.03643957933302 6072614.87315468 261176.892429756 8.85726806814259 6072618.47086653 261180.364657152 8.67809655695216 6072622.09328803 261183.811098248 8.49892504576172 6072625.74023434 261187.231577206 8.31975353457129 6072629.4115194 261190.625919512 8.14058202338085 6072633.10695591 261193.993951986 7.96141051219042 6072636.82635531 261197.335502791 7.78223900099998 6072640.56952785 261200.650401439 7.60306748980955 6072644.33628255 261203.938478806 7.42389597861911 6072648.12642722 261207.199567131 7.24472446742868 6072651.9397685 261210.433500033 7.06555295623824 6072655.77611182 261213.640112517 6.88638144504781 6072659.63526146 261216.819240981 6.70720993385738 6072663.51702051 261219.970723225 6.52803842266694 6072667.42119094 261223.09439846 6.34886691147651 6072671.34757355 261226.190107315 6.16969540028607 6072675.29596801 261229.257691847 5.99052388909564 6072679.26617289 261232.296995546 5.8113523779052 6072683.25798561 261235.307863347 5.63218086671477 6072687.27120251 261238.290141636 5.45300935552433 6072691.30561884 261241.243678255 5.2738378443339 6072695.36102877 261244.168322514 5.09466633314347 6072699.43722538 261247.063925198 4.91549482195303 6072703.53400071 261249.930338572 4.73632331076259 6072707.65114573 261252.767416392 4.55715179957216 6072709.86791767 261254.277096468 4.46104356105825 6072711.7884504 261255.575013909 4.38010802840032 6072715.94570362 261258.352987879 4.22001586904138 6072720.12269329 261261.101196569 4.07972385820051 6072724.31920629 261263.819499766 3.95923199587772 6072728.19858495 261266.29477465 3.86583356410595 6072728.53496795 261266.507854467 3.85854028207302 6072732.75885188 261269.183448712 3.7776487167864 6072736.98273581 261271.859042957 3.71655730001786 6072741.20661973 261274.534637202 3.6752660317674 6072745.43050366 261277.210231447 3.65377491203503 6072747.90317353 261278.776529525 3.65038220174697 6072749.65438759 261279.885825692 3.65208394082075 6072751.92009413 261281.321024077 3.65933586995157 6072753.87827152 261282.561419937 3.66806537810594 6072758.10215545 261285.237014182 3.68689535209632 6072762.32603937 261287.912608427 3.7057253260867 6072766.5499233 261290.588202672 3.72455530007708 6072770.77380723 261293.263796917 3.74338527406746 6072774.99769116 261295.939391162 3.76221524805784 6072779.22157509 261298.614985407 3.78104522204822 6072783.44545901 261301.290579652 3.7998751960386 6072787.66934294 261303.966173897 3.81870517002898 6072791.89322687 261306.641768142 3.83753514401936 6072796.1171108 261309.317362387 3.85636511800974 6072800.34099472 261311.992956632 3.87519509200012 6072804.56487865 261314.668550877 3.8940250659905 6072808.78876258 261317.344145122 3.91285503998088 6072813.01264651 261320.019739367 3.93168501397126 6072817.23653044 261322.695333612 3.95051498796164 6072821.46041436 261325.370927857 3.96934496195202 6072825.68429829 261328.046522102 3.9881749359424 6072829.90818222 261330.722116347 4.00700490993278 6072834.13206615 261333.397710592 4.02583488392316 6072838.35595007 261336.073304837 4.04466485791354 6072842.579834 261338.748899082 4.06349483190392 6072846.80371793 261341.424493328 4.0823248058943 6072851.02760186 261344.100087573 4.10115477988468 6072855.25148579 261346.775681818 4.11998475387506 6072859.47536971 261349.451276063 4.13881472786544 6072863.69925364 261352.126870308 4.15764470185582 6072867.92313757 261354.802464553 4.1764746758462 6072872.1470215 261357.478058798 4.19530464983658 6072876.37090543 261360.153653043 4.21413462382696 6072880.59478935 261362.829247288 4.23296459781734 6072884.81867328 261365.504841533 4.25179457180773 6072889.04255721 261368.180435778 4.27062454579811 6072893.26644114 261370.856030023 4.28945451978849 6072897.49032506 261373.531624268 4.30828449377887 6072901.71420899 261376.207218513 4.32711446776925 6072905.93809292 261378.882812758 4.34594444175963 6072910.16197685 261381.558407003 4.36477441575001 6072914.38586078 261384.234001248 4.38360438974039 6072918.6097447 261386.909595493 4.40243436373077 6072922.83362863 261389.585189738 4.42126433772115 6072924.70420458 261390.770094987 4.42960332075588 6072927.05740544 261392.26095307 4.44009431171153 6072931.2790562 261394.940068639 4.45892428570191 6072935.49490193 261397.628307422 4.47775425969229 6072939.70117184 261400.331501054 4.49658423368267 6072943.89403301 261403.055441032 4.51541420767305 6072944.15219862 261403.22438267 4.51657613004843 6072948.06956644 261405.805862408 4.54826010156688 6072952.22374354 261408.588426884 4.61288542665778 6072956.35240316 261411.40870516 4.70935080051515 6072960.45122919 261414.272158356 4.83765622313908 6072964.51572904 261417.184118394 4.99780169452944 6072968.54121297 261420.14976716 5.18978721468633 6072972.52277456 261423.174114343 5.41361278360964 6072974.27067508 261424.533480791 5.52290803281679 6072976.45539703 261426.261817103 5.66927840129947 6072980.33607684 261429.414553297 5.95678406775582 6072984.16367451 261432.631526623 6.27612978297859 6072984.39809743 261432.832117361 6.29687830899066 6072987.93712684 261435.911843499 6.61329962706444 6072991.65538567 261439.254592747 6.95053008871966 6072995.31741819 261442.658845846 7.28776055037488 6072998.92220717 261446.123657192 7.62499101203011 6073002.46875132 261449.648064362 7.96222147368533 6073005.95606551 261453.231088374 8.29945193534055 6073009.38318106 261456.871733968 8.63668239699577 6073012.74914601 261460.568989876 8.973912858651 6073016.05302539 261464.321829107 9.31114332030622 6073019.2939015 261468.12920923 9.64837378196145 6073022.47087409 261471.990072663 9.98560424361667 6073025.5830607 261475.903346969 10.3228347052719 6073028.62959685 261479.867945154 10.6600651669271 6073031.60963631 261483.882765964 10.9972956285823 6073034.5223513 261487.946694198 11.3345260902376 6073037.36693275 261492.058601013 11.6717565518928 6073040.14259053 261496.217344239 12.008987013548 6073040.87881701 261497.346107654 12.099880209836 6073042.8489342 261500.421526536 12.3462174752032 6073045.48916866 261504.667547714 12.6834479368585 6073048.06857887 261508.950801071 13.0206783985137 6073050.59263653 261513.266913192 13.3579088601689 6073053.06695956 261517.611735727 13.6951393218241 6073055.49729227 261521.981323658 14.0323697834794 6073057.88948677 261526.371912644 14.3696002451346 6073060.24948569 261530.779895586 14.7068307067898 6073062.58330597 261535.20179854 15.044061168445 6073064.89702355 261539.634256101 15.3812916301003 6073067.19675886 261544.073986372 15.7185220917555 6073069.48866278 261548.517765617 16.0557525534107 6073070.10585429 261549.715769781 16.1466457496986 6073071.77850212 261552.96260935 16.3929830150659 6073074.06832131 261557.407463461 16.7302134767211 6073076.3581405 261561.852317572 17.0674439383764 6073078.64795969 261566.297171684 17.4046744000316 6073080.93777888 261570.742025795 17.7419048616868 6073083.22759807 261575.186879906 18.079135323342 6073085.51741726 261579.631734017 18.4163657849973 6073087.80723646 261584.076588129 18.7535962466525 6073090.09705565 261588.52144224 19.0908267083077 6073092.38687484 261592.966296351 19.4280571699629 6073093.74755623 261595.607566155 19.628449941733 6073094.03241709 261596.159467412 19.6703393813089 6073094.68126403 261597.408786388 19.7642261818336 6073097.02124529 261601.827401803 20.0805267236506 6073099.41627499 261606.216423014 20.3700473543952 6073101.86597893 261610.575164246 20.6327880740677 6073104.36997432 261614.902944454 20.8687488826679 6073106.92786994 261619.199087431 21.0779297801959 6073109.53926612 261623.462921914 21.2603307666516 6073112.20375482 261627.693781686 21.415951842035 6073114.92091974 261631.891005686 21.5447930063462 6073117.69033631 261636.053938105 21.6468542595851 6073120.51157183 261640.181928493 21.7221356017518 6073123.38418547 261644.274331861 21.7706370328462 6073126.30772841 261648.330508778 21.7923585528683 6073127.22759466 261649.58494785 21.7936545797036 6073129.28174384 261652.349825476 21.7873001618183 6073132.30576707 261656.331653944 21.7554618596959 6073135.37932562 261660.275372029 21.6968436465013 6073138.50193924 261664.180363534 21.6114455222345 6073141.67312003 261668.046018312 21.4992674868953 6073144.89237251 261671.871732362 21.360309540484 6073148.15919366 261675.656907924 21.1945716830003 6073150.53531074 261678.351000197 21.058966416099 6073151.47307306 261679.400953572 21.0031153642291 6073152.9671474 261681.05853486 20.9145815705301 6073154.8264095 261683.109734733 20.8047476044393 6073158.1843658 261686.814343955 20.6063798446494 6073160.763842 261689.660108 20.4539999835601 </PntList3D> <Feature code="MX"> <Property label="type" value="MXMasterString"/> <Property label="subreference" value="GC00"/> <Property label="chainage" value="0.0 5.0 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 70.0 75.0 80.0 85.0 88.2994290000857 90.0 95.0 98.9018804871495 100.0 105.0 110.0 112.189696966018 115.0 120.0 125.0 130.0 135.0 140.0 145.0 150.0 155.0 160.0 165.0 170.0 175.0 180.0 185.0 188.299429006088 190.0 195.0 200.0 205.0 210.0 215.0 220.0 225.0 230.0 235.0 240.0 245.0 250.0 255.0 260.0 265.0 270.0 275.0 280.0 285.0 290.0 295.0 300.0 305.0 310.0 315.0 320.0 325.0 330.0 332.682017857508 335.0 340.0 345.0 350.0 354.601808425735 355.0 360.0 365.0 370.0 375.0 377.927009729621 380.0 382.682017999911 385.0 390.0 395.0 400.0 405.0 410.0 415.0 420.0 425.0 430.0 435.0 440.0 445.0 450.0 455.0 460.0 465.0 470.0 475.0 480.0 485.0 490.0 495.0 500.0 505.0 510.0 515.0 520.0 525.0 530.0 535.0 540.0 545.0 550.0 555.0 560.0 565.0 570.0 575.0 580.0 585.0 587.214284267995 590.0 595.0 600.0 605.0 610.0 610.308530000099 615.0 620.0 625.0 630.0 635.0 640.0 645.0 647.214284267995 650.0 655.0 660.0 660.308530010594 665.0 670.0 675.0 680.0 685.0 690.0 695.0 700.0 705.0 710.0 715.0 720.0 725.0 730.0 735.0 740.0 745.0 746.34764214125 750.0 755.0 760.0 765.0 770.0 775.0 780.0 785.0 790.0 795.0 800.0 805.0 806.34764214125 810.0 815.0 820.0 825.0 830.0 835.0 840.0 845.0 850.0 855.0 857.971154663587 858.592234968289 860.0 865.0 870.0 875.0 880.0 885.0 890.0 895.0 900.0 905.0 910.0 915.0 920.0 921.55556240794 925.0 930.0 935.0 940.0 945.0 950.0 955.0 958.592234647177 960.0 962.231557028037 965.0 970.0 973.840842414378 "/> <Property label="bearing" value="0.640862287712308 0.640862287712308 0.640862287712308 0.640862287712308 0.640862287712308 0.640862287712308 0.640862287712308 0.640862287712308 0.640862287712308 0.640862287712308 0.640862287712308 0.640862287712308 0.640862287712308 0.640862287712308 0.640862287712308 0.640862287712308 0.640862287712308 0.640862287712308 0.640862287769315 0.640862287712308 0.640862287712308 0.640862287712587 0.642431029873802 0.649573887016659 0.656716744159517 0.6598448826824 0.663859601302374 0.671002458445231 0.678145315588088 0.685288172730945 0.692431029873802 0.69957388701666 0.706716744159516 0.713859601302374 0.721002458445231 0.728145315588089 0.735288172730946 0.742431029873803 0.74957388701666 0.756716744159517 0.763859601302374 0.768573071311071 0.771002458445231 0.778145315588088 0.785288172730946 0.792431029873803 0.79957388701666 0.806716744159517 0.813859601302374 0.821002458445231 0.828145315588088 0.835288172730945 0.842431029873802 0.84957388701666 0.856716744159517 0.863859601302374 0.871002458445231 0.878145315588088 0.885288172730945 0.892431029873802 0.899573887016659 0.906716744159517 0.913859601302374 0.921002458445231 0.928145315588088 0.935288172730946 0.942431029873802 0.94957388701666 0.956716744159516 0.963859601302374 0.971002458445231 0.974833912527385 0.978145315588089 0.985288172730946 0.992431029873803 0.99957388701666 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789904866 1.00614789905359 1.00614789904866 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00614789905359 1.00593233760527 1.00446408323527 1.00160693997638 0.997360907828599 0.991725986791931 0.991141507909798 0.984702176866374 0.976289478051928 0.966487890348593 0.955297413756369 0.942718048275257 0.928749793905255 0.913392650646365 0.90614789904129 0.896862179934605 0.880195513267939 0.863528846601272 0.862500413232624 0.846862179934606 0.830195513267939 0.813528846601272 0.796862179934605 0.780195513267939 0.763528846601272 0.746862179934605 0.730195513267939 0.713528846601272 0.696862179934605 0.680195513267939 0.663528846601272 0.646862179934605 0.630195513267939 0.613528846601272 0.596862179934606 0.580195513267939 0.575703372797106 0.563899394306409 0.548941715933839 0.535372926450159 0.523193025855368 0.512402014149465 0.502999891332451 0.494986657404326 0.488362312365091 0.483126856214743 0.479280288953285 0.476822610580715 0.475753821097035 0.475703372782011 0.475703372782011 0.475703372782011 0.475703372782011 0.475703372782011 0.475703372782011 0.475703372782011 0.475703372782011 0.475703372782011 0.475703372782011 0.475703372782011 0.4757033727823 0.477256073544055 0.480775486123333 0.493275486123333 0.505775486123333 0.518275486123333 0.530775486123333 0.543275486123333 0.555775486123333 0.568275486123333 0.580775486123333 0.593275486123333 0.605775486123333 0.618275486123333 0.630775486123333 0.634664392143183 0.643275486123333 0.655775486123333 0.668275486123333 0.680775486123333 0.693275486123333 0.705775486123333 0.718275486123333 0.727256072741276 0.730775486123333 0.736354378694113 0.736354378694113 0.736354378694113 0.736354378694113 "/> <Property label="radius" value="999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 -6461.53510682965 -2311.92617603621 -1407.82106980075 -1012.04811047379 -789.968601895476 -779.414684002944 -647.814876305903 -549.019583623988 -476.370492163355 -420.701154393342 -376.681602949063 -341.001343836779 -311.495665874923 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -300.0 -319.445487264195 -350.551636830464 -388.369271194918 -435.333166967764 -495.21781715718 -574.205865911496 -683.173086362036 -843.18445479367 -1101.07621909467 -1586.2326090253 -2835.69861051685 -13356.6615713783 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 999999.9 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 400.0 999999.9 999999.9 999999.9 999999.9 "/> </Feature> </Breakline> </Breaklines> </SourceData> </Surface> <Feature code="MX"> <Property label="featureset" value="publicstyles\mfw simple design.fns"/> <Property label="styleset" value="publicstyles\mfw simple design.pss"/> </Feature> </Surfaces> </LandXML>
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
Thanks Phil! We're using gINT V8i SS2 Version 08.30.04.285 Professional Plus. Do you have a workflow suggestion for the InRoads side of things? I've finally found last night that the "AlignmentsToLandXML" format works but only when I copy and paste what shows up on the preview instead of using the export function within InRoads. I'm not great with InRoads and asking our track folks to help out on their end. Thanks for the example XML file as well. We're bridging the gap!
I had trouble with an alignment import recently, and if I remember correctly there is a 1000 point limit on the alignment. I had to break it up into north and south sections and import them separately
****Actually, I was trying to convert a polyline to alignment, and that is what has the 1000 point limit, so disregard my answer above!
Hi Lucy,
This is very long alignment and it is likely too much for gINT to handle it, especially if it has long or too many curves. Curves are broken into line segments (secants) during gINT LandXML import, which dramatically increases the number of points in an incoming alignment. This will likely choke gINT.
One workaround would be to break a long alignment into multiple alignments of maybe 10-20 mile segments, so you would have 'multiple' alignments in gINT.
Another possible workaround would be to import alignment as a polyline via DXF in gINT, and then turn it into baseline or alignment in gINT.
But considering you are a gINT user, you are entitled to gINT Civil Tools, an accompanying product to gINT (no additional cost) that is MicroStation based, directly working with design files (dgn files) as InRoads. It has much greater capabilities in terms of CAD/Civil work than gINT itself. Whenever alignments, surfaces, and profiles are involved gINT Civil Tools might be a better solution. Many folks will likely be fairly soon switching from InRoads to OpenRoads, and gINT Civil Tools, besides being a standalone product, it is also included in OpenRoads, so it has direct connectivity to gINT and it is designed to deal with alignments, surfaces, profiles, sections, site plans, etc.
www.Gintegro.com
Thanks! We actually do have several ALG files to depict the alignment. But it's good to know about the limits of what we can import into gINT so we'll try the smaller segments first.
Follow-up questions:
Thanks in advance.
