Hi all, I'm in the process of converting a clients gINT system from AGS3 to AGS4. Data template all done as are the logs etc. I then came to do their monitoring data, and realised that it's one I haven't done for anyone before. I set up their Graphic Table report to duplicate their original i.e. columns for BH, Date / Time, CO2, O2, CH4, H2S, Flow and Water Depth etc. Pulled in all the relevant Table Text entities, set the Output Conditions to only report the relevant reading. I populated a test project with some readings and outputed it. Much to my horror (and that of my client) each reading is coming out on a separate line i.e. there's a separate line for each O2 reading, each Water Depth reading and so on.
What I'm after is to have each data / times worth of readings to output on the same line, mainly for the readers sanity, and partly to save a small rain forests worth of paper. If they take 6 different readings each round of readings for 10 BHs, that should be 10 lines on the output, not 60 (if this is translated to a hundred or so BHs with months of monitoring, it would generate 10s if not hundreds more pages than are necessary). I have tried a variety of things, all to no avail (I even checked this behaviour with a Text Table report... the same result)
. Is it me or am I missing a way of doing this
Hi Miles,
We don't have a graphic table report for that, but I just made a small example based on what you described. I assume the data you are pulling in comes from the MonD table. In AGS 4 the Keyset of the Monitoring tables are different than before.
I set the report properties to match the keyset of the MOND table which is POINTID, ItemKey, Datetime
I also set the report properties to consolidate Rows, which is found in the report structure tab.
Lastly here is the output it will consolidate results from the same date/time
Hi Kirk, thanks for getting back to me. I have (and had) all those settings dialled in. I'm using the gint std ags 4_0.gpj for some data (I've just changed the reading type to GOX and WDEP to match what I've got on my report). The Table Text Entity Properties for the O2 reading is <<Format(<<MOND.MOND_RDNG>>,0.00)>> with an Output Condition of <<MOND.MOND_TYPE>> = "GOX" (the others are the same just a different Output Condition) and I am still seeing this
I was expecting to see what you had so I'm a bit flummoxed????
Hi Miles shoot me the library and project and I'll take a look at it real quick kirk.johnson@Bentley.com
Actually I think I know what it might be. Since you are calling in multiple tables, I bet your point ID expression is for a specific table something like <<MONG.PointID>>
Try just using the System point id expression in the point id text expression of the text table. <<PointID>>
Answer Verified By: Miles Davis
Hi Miles
AGS format is an interchange standard, and clearly not a great working database structure for some things. You can create tables for each different instruments then import and export AGS format from these new tables.
https://cdn.datgel.com/pdfs/Articles/ags_20051019_caronna_and_wade.pdf
regards
Phil
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
