I downloaded the sample gINT rule GR019, unzipped the project and library files, opened them in gINT and they worked exactly as described. Then I copied both the GR019 and GR019 COMMON PROCEDURES rules from the sample library to my own library and tried them again with the same sample project. They still worked. Then I opened a project I use with my library and they don´t work anymore. Is this a bug or am I doing something wrong?
My project has different names for the Alignment, Station and Offset columns than the sample project, so I changed that in the rules code but it didn´t help. Changing my project column names instead to Alignment, Station and Offset didn´t help either. I can´t see any other substantial differences between the project that works and the one that doesn´t.
The error is in the line "CallByName Me, gINTRules.ProcedureName, vbMethod" of the GR019 rule and when I try to run the code it says "(10091) ActiveX Automation: no such property or method. No Pre- or Post-process code specified for table POINT".
Thank you very much for any insight into this!
Tereza Smejkalova, Prague
If you are using the project that doesn't come with the rule then you would need to modify the rule to match your project field names or use the same field names. But the rule does need to be called into the point table. This is most likely the error you are seeing. Make sure once you add it you update your datatemplate so that future project with have that table property.
Answer Verified By: Tereza Smejkalova
Thank you so much! Yes, this is exactly what was causing the error. I must have missed that part when reading the rules manual. Now it works!
