I am looking for guidance on how best to generate an N60 value in the database itself. The main problem I have is I just can't code worth a darn, and to be honest, I don't completely (ie barely) understand gint rules. I currently use a modified version of the OHDOT calculations, which are all done in the reports themselves using User System Data modules, not in the database itself. This is what this part of our db looks like. I'd love to generate a permanent N60 entry in the N60 field. Is a rule the best way to go about it? Is there a more direct way of going about it? I know Access allows formulaic calculations within the database itself. That's what I want, in reality, something that automatically gives me an N60 when the proper fields are populated.
Hi Jeff,
You are right - this would require a gINT Rule.
Our Professional Services group can create gINT Rules for you. If you are interested, please email me directly at jesse.greenwald@bentley.com, and we can discuss.
Thank you,
Jesse
The DGD Tool gINT Add-In calculates N60 and (N1)60, see docs.datgel.com/.../input
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
