Dear Aparna,
I want to export fence to DGN to work with Microstation/Autocad. When I try for that it is asking export file and seed file. How we can I download that (I need in meters). Please give me a solution
Hello Alaa,
When exporting to DGN format, one has to provide the seed file. If you are using the standard gINT files for creating a project and gINT std library file along with it, you should find the sample seed files in C:\Users\Public\Documents\Bentley\gINT\seed.
Can you help us by providing the code for 'Average RQD' to display in the fence?
Adding text entities to fences is done by adding a Text Vs Depth Entity column in the report fence design. In the screenshot you have provided, I already see text vs depth columns set for N values, TCR and RQD. Adding a new column will be similar to these. Just make sure you provide the correct <<Columnmame.Fieldname>> which in your case seems to be <<Core.RQD>> in the text expression.
You will have to make sure first if whether Core is the Name of this column or a caption. If it is the caption then you need to provide the actual Column Name. Same goes for RQD whether it is the actual name or the nick name.
Fences Tutorial can guide you through adding new Text vs Depth Entities. But bear in mind, the text expressions used in the tutorial correspond to the sample files used for training. In your case, you will have to use your project table and field names.
Thanks Aparna. I will check and work on it with in the Fence, then it will be easy to analyze in a single view.
