After editing the standard gINT Logs environmental borehole template to match my companies format, I am having 3 problems editing the 'Page 1 Header Block' for Groundwater Levels:
1. When editing the 'After Drilling' block, I've tried changing the text to 'After Drilling (BGS)' but the output becomes 'After Drilling (BGS) Drilling', how can I remove the second Drilling from this text?
2. Despite filling out the After Drilling (AD) field in the Water Levels table in the Input Function, the AD depth is not being displayed in the relevant block mentioned above despite showing up in the log below at the correct depth. Instead of a depth value, the only text that appears is '---'. How can I resolve this?
3. The 'After Drilling' symbol is showing up within the Report Design > Edit Log Blocks screen, but it is not appearing in the 'Output' preview or when the log is saved to pdf. It's not hidden.
Below are screenshots I've taken to illustrate my issues:
The only solution I can think of is to uninstall and re-install the gINT Logs software and revise the standard template all over again, but I'd like to avoid that if possible since it is time consuming.
Any help or advice is greatly appreciated.
Hello T.W,
Please send me your contact information via a private email aparna.matange@bentley.com so that we can trouble shoot this together.
We ended up putting the correct text expression for the After drilling entity, edited the text expression to remove the repeated 'DRILLING' statement and also modified the discrete graphics.
Answer Verified By: T.W. Landis
I deleted the groundwater level symbols from the header, can you help me put them back on?
Hi Christina.
We will have to troubleshoot it with your library and project files. Please send me a private email at aparna.matange@bentley.com and I will contact you.
We created a copy of the original header and made it show the changes they wanted on this new header. Then we referenced this new header to the report.
