Can someone please help me troubleshoot why my companies address is not showing up in the final log despite it being entered into the template? Only the zip code is appearing in the preview and final pdf once saved.
Here are a couple of screenshots to illustrate what I'm talking about. I've blocked out my companies info for privacies sake:
Hi TW,
If you use the standard company information functions in the text expression all you need to do is goto HELP..Company information and fill out as needed.
If you want to hard code it you can open the text entity and manually type it in the text expression. This is not the recommended way. Using the above expression is more efficient and maintainable.
Answer Verified By: T.W. Landis
Thank you, very simple solution.
