I am trying to export fence diagrams to pdf, but when I do, the text is jumping up on the line. I cannot figure out why. I exported the same file to a .jpg file and the text is in the proper place. Can anyone help with this issue? I have examples below, the only difference is the pdf vs jpg option at export. Thank you
Check the "vertical alignment" in your Text vs Depth properties box, main tab. "Middle" will put the text on the line, and "top" will put it just below the line.
I am not sure of the difference between exporting to pdf vs jpeg,
Hi Brenda,
I would also check the Vertical offset property of the text versus Depth. To move text off of line slightly choose a small negative number IE -0.05 and make sure the offset Units is set to page
your suggestion worked,
thank you
