I'm trying to plot water depths but my advance filter is not working.
In our gINT database - monitoring records contain WDEP - Depth to Water and DBSE - Depth to base of installation monitoring record.
I'm trying to plot the WDEP ONLY so I added an advance filter in gINT Projects. I use a "Filter by Depth-Related Property"
However it is still plotting DBSE when I add "equal to WDEP"
Any ideas?
GINT monitoring DATA
Openroads Advanced Query Filter
Example of Borehole Data
Hi Chris
The Advanced Query tool allows you to filter the boreholes that will be loaded, not the content of the item types. In order to limit elements to be displayed you can use levels; you have 2 options : use "MOND_Type" as the identifier for the water level, it will load all the water levels but will put them on different levels based on the different types, so you will have 2 levels : WDEP and DBSE, you will be able to filer by turning on and off levels. The second option consists of creating a query in the ProjectExplorer and selecting only the WDEP elements and moving them to another level. The 1st option is probably the simplest one.
Let me know if that helps
Nicolas
