Good Day,
Would you advise if there is any ArcGIS toolbar for gINT 8.30.03.077 can be use with ArcMap 10.6.1 . if yes, how to get the extension or the setup file.
Many Thanks
You will need gINT 8.30.03.185 and later to work on ArcGIS 10.0 or later versions and would recommend you to install the latest version of gINT.
Please refer to this thread for ArcGIS Manual, and links to some more posts that talk about ArcGIS 10.0 and its fixes.
390726
