Doe not appear to work! Consistently get a "gINT has stopped working" dialog. Reinstalled 10.00.00.69 and no problem. This does mean I cannot look at AGS files with Excel
Suggestions
Thank you
I had a room of 8 people try exporting to excel, for people with office 365 excel it worked, for people with offline installed excel failed. Bentley, time to fix this one.
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
Hi Phil
I have still not managed to get 1.07 working yet. apparently we are moving over to 365 very soon so we shall see if that helps
Roger
Just as a test, try running gINT in 'Windows 8 compatibility mode'. This solved a different issue I was having with the latest version of gINT....might be worth a try.
My PC doesn't know that Windows 8 exists as I am still on Windows 7. Is this the issue?
You could try the following:
right click on your desktop gINT icon
go to 'Properties', then go to the 'Compatibility' tab
set compatibility mode to Window 7
I'm not sure if that will help or not, but again, it may be worth a try.
Good Luck!
Mike
