C:\Users\Public\Documents\Bentley\gINT\temp
Hi there.
We had noticed an issue that one of our servers running gINT had run out of disk space.  Further investigation led to the discovery that the folder location C:\Users\Public\Documents\Bentley\gINT\temp was 60gb in size.  This appeared to be full of GBK, TXT and XML files (sometimes .gdw and others)
We then looked at the same locations on a local install and found the same types of files.
If these are temporary files is there any reason that gINT is not clearing them once they have been used?
Paul
